Old 03-19-2016, 02:45 PM   #6 (permalink)
ascendedmind
Originally Posted by Ryland View Post
You said you have a carb rebuild kit, you can do the work with the carb on the car and most of the vacuum hoses left in place, I'd repair or replace the base gasket at the same time.
The accelerator pump wears out over time and leaks, so a rebuild might fix multiple problems you didn't know about.
Thank you Ryland, rebuild the complete carb? Or just repair/replace base gasket & accelerator pump?
Now if you are going to repair/replace base gasket this would require removing from the car. What I'm I misunderstanding?
