Old 03-19-2016, 09:51 PM   #1 (permalink)
ascendedmind
Which VW 13" Aluminum Wheels Will Fit a 1985 Honda CRX HF?
Which water cooled VW 13" Aluminum Wheels Will Fit a 1985 Honda CRX HF, if any?
& will my 175 70 13" size Toyo tires fit?
Or which 13" aluminum alloy wheels would you recommend which are lighter than my steel wheels?
I want to replace my light weight steel wheels with inexpensive aluminum alloy wheels, which I will polish into a mirror like finish.
My wheels:
Bolt Pattern: 4 x 100mm
Backspacing?
5" Wide
13" Diameter
Weight 10 pounds each
