Old 03-21-2016, 10:03 AM   #5 (permalink)
oil pan 4
Where are you going to be?
Evap coolers don't work so well every where.
For them to kind of work they need to be used where relative humidity is 50% or less.
If you want to use battery power, then 12 batteries in series is not the way to go. Most solar power battery systems use 12, 24 or 48 volts.
There are few things that can be powered off 120 volts DC, also 120 volts DC presents an extreme arcing hazard.
