Old 03-22-2016, 06:56 PM   #2681 (permalink)
e*clipse
Permanent Apprentice
Thanks, Paul.
I've caught up to where you and Shaggy are; regarding debugging.
Can the controller work with no position feedback? Can it be forced into a v/hz mode? This would be helpful for debugging in general.
Also, I've read the sections about I/O pins and the QEI interface in both the FRM and the 6010 controller - neither mention the transition voltages for the pins, unless I missed something.
In general (from Wikipedia) the transition voltage for CMOS logic is 1/3Vdd for the low transition and 2/3Vdd for the high transition. In other words, Shaggy should see a transition in the QEI output when the pin voltage exceeds 3.333V ( his 3.8 V should be OK) I think it would be wise to increase that voltage, as Paul suggested. But it should work.
*** edit ***
Thanks for the info on the oscillator! :-)
- E*clipse
