Old 03-22-2016, 07:23 PM   #2683 (permalink)
e*clipse
Permanent Apprentice
- Got the schematics - thanks!!
Regarding V/hz - we just need a rotating magnetic field. This should work slowly at no load for both synchronous and asynchronous motors. I mean your standard induction motor works with a magnetic field rotating at 60hz....
So, maybe a stupid test would be to let the throttle setting just directly change the speed - from 0 to maybe 60hz at the fastest.
Meanwhile, stuff like "is the position feedback working properly?" " Is the current sensor working properly" could be verified. Heck, it could also be used to figure out if a 4 pole or two pole motor was connected...
Maybe all this could be another "motor" - a separate include file.
If any of that rambling made any sense, let me know.... I'll try to include it w/ the translation.
Take care,
E*clipse
The Following 2 Users Say Thank You to e*clipse For This Useful Post:
MPaulHolmes (03-22-2016), thingstodo (03-22-2016)
