Old 03-23-2016, 03:47 AM   #232 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Unrated tires
Originally Posted by oldtamiyaphile View Post
Well, I meant maximum, though even that is a recommendation rather than an absolute value. Either way there's nothing written on some sidewalls these days.
Picture nesasary or At least a sorce. The law suits would make the cup run over from idiots putting 100+ psi just becuas they don't know any better and the air kept going in if you don't think so look at the coffee cup at McDonalds
The other part of that safety notice on your sidewall is the rated load @psi. This is required for proper tire selection
eg. My LT 235/85R16 has 2 ratings
1 for single. "Max load single 1380kg(3042lbs)at 550 kpa(80psi) cold" 6084lbs per axel max
1for Dual. "Max load dual 1260kg ( 2774 lbs) at 550 Kpa (80psi ) cold" 11094lbs per axel
this is off of a set of snow tires purchased in Jan2016
The reason for reducing load rating on dual is because less sidewall deflation is allowed for dual or the sidewalls will rub holes in each other causing both to fail
I have seen this during harvest season in California
Especially if there is not a scale between the field and the canary, we are talking semi trailers overloaded with ,tomatoes ,grapes ,and all kinds of fruits and nuts. Their is only 1 northbound and no southbound scale between Modesto, California and Fresno ,California I worked for Big Jim's Tire Service out of Atwater , California in the middle
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
