Old 03-25-2016, 01:05 AM   #2689 (permalink)
WindyDrew
AC Customs car builder
S10 - '99 Chevy S10 Base
90 day: 23.5 mpg (US)
Purple People Eater - '95 Geo Metro LSi
90 day: 34.76 mpg (US)
Volt - '14 Chevy Volt Premium
90 day: 1680 mpg (US)
New feature for AC Controller
ITS ALIVE!!!!!!!!!!! Just worked with Paul to get my controller turning my leaf motor. We're designing a circuit to allow a button to inverse the throttle for reverse on my race car. I need some help, Paul is busy with work so I was hoping someone could help me with the code. I want to signal high on the led pin (change the LED pin to Digital input pin) is forward in normal state and then signal low would invert the throttle. I'm sure there needs to be some safety built into the code as well. The wiring is planned out that we take +5v from supply side of R53 with a 4.7kOhm resistor to the left side of LED. R57 populated with 1kOhm resistor and a 0.1mF from the microprocessor side of R57 to the ground pin at the end of the microprocessor 2 pins to the right. LED left and right to the momentary switch. How does that sound to you guys? Can you give any thoughts to the safety details of this added code? Let me know
Thanks,
AC
