Originally Posted by thingstodo
EDIT - I hit send before I should have - Paul's code new restricts regen to disengage at 0 rpm for forward. That part is done and working.
So - to review:
Code:
button brake description
Off Off normal forward controlled by accelerator pedal
Off On normal forward but using friction brake pads using hydraulic
pressure from how far the brake is pressed
On On regen braking as well as friction braking. I'm not sure how
much regen braking when you press the button, or if it
increases as you hold the button
Now, we'll add the low rpm - like maybe 50 rpm or something
Code:
Off On assuming we're stopped below 50 rpm
On On assuming we're stopped below 50 rpm, change to reverse.
But the throttle works in reverse as long as you don't have
the brake pedal to the floor?
Off On assuming we're stopped below 50 rpm, after going reverse
Off Off back to normal operation in forward
This description assumes no regen braking without pressing the brake pedal and having that switch enable the regen/reverse button on the dash, or steering wheel, or whatever. That is what you meant by
I think we're getting close to a description that would be required by anyone who takes on the programming mods ...
Not sure that will work after thinking about it. I would like the gas pedal to work as a regen pedal once the reverse button was engaged. I doubt I'll want to hit the brake, gas, and regen button just to start regen braking. Maybe a brake signal before engaging reverse would be best.
