pin it =100% throttle, open, full throtle,on the floor, giveing it everything, run the throttle against the fule stop pin governor
So I pin it hit 60 and off unless thire are 25 of my160hp missing from the fan..... Go from7/8 throttle to 100% accelerating to until the transmission hit its predetermined shift point 60mph unless the 25hp load plus 136hp to over come gravity, rrc, cda, and parasitic load,= 161hp mytruck only has 160 available so it will slow down at 100%throttle.
supper= extremely
droping= reducing
fill= physically perceivethe loss of motive power, a sudden 16%loss of hp is noticeable
dose= opposite of don't
ponnys=many small horses
ckass8=class 8 =semi, 18 wheeler, heavy duty truck
pulling a grade empty= hill at tare,just me no load ,as apposed to pulling 10,000lbs trailer
No computer on my engine or cruise.= old school if i can start it I can drive on 9volt Battery with cruise control working it takes 6watts to run the engine@ a minimum of 9vdc to keep the fss open fss=fule shut off solenoid 14amps to open and .5amps to holdit there, its all mechanical cruise is vacuum actuated 1970s style.
Baker-Gradea3500ft hill climb see link Baker Grade =link Baker to Barstow =direction of travle .
I can tell you, I can show you, I can do it, but not written I'm trying at least. You ever see those misspelled mixed up letters that 80% of people can reed and don't notice untell the end when they tell you its messed up. That's me part of the 80%and Android has no spell/grammar check so that is no help for dyslexia ,and add don't make it any better.
and your options?
I figured this was to technical of a question to ask with my English-companion skills . Nothing ventured Nothing gained this was a 5hr venture for the original write-up. I think thire are enough 80%ers hear to see a payoff. Thank you
Gumby be flexible.
