Old 03-26-2016, 02:48 PM   #168 (permalink)
planejob
BeginnerModder
Do you have any plans for the transmission and\or governor?
Yes, I'm going to pop the "top hat" off the tranny and check out the 5th. A quick search of the ol' googlator indicates it can be serviced in place - no complaints here. I'd go back to the junk yard and ***** but... I'm probably outside of the 30/30 warranty (feet/seconds, respectively).
The governor is cool. I love the way it works, but not the setting. I've not yet started investigating what I can do, but I'd like to:
  1. Remove the HEAVY return spring.
  2. Adjust the governor up to 32-3300 rpm.
  3. Retain the governor to avoid over-revving
