Old 03-26-2016, 02:59 PM   #2699 (permalink)
WindyDrew
AC Customs car builder
S10 - '99 Chevy S10 Base
90 day: 23.5 mpg (US)
Purple People Eater - '95 Geo Metro LSi
90 day: 34.76 mpg (US)
Volt - '14 Chevy Volt Premium
90 day: 1680 mpg (US)
Originally Posted by thingstodo View Post
I was not thinking that you would release the throttle before beginning regen braking, but you can do that if you like.
What I was describing does have side effects - if the Reverse button wiring were to short out during a race, worst case you would be going full throttle and switch to full regen braking. Enforcing the release of the throttle between throttle and regen braking would make a shorted Reverse button less of a problem ... but it would still be a problem the next time you went to accelerate!
Do you have a preference on the Reverse button connection? I'd prefer an analog input, and a couple of resistors wired into the button to verify that the button is still connected (4.5V) and not open circuit/disconnected (5V), pressed (0.5V) instead of shorted out wiring (0V).
I was hoping to use an existing hook up like the led output. I think I would rather run it as forward is high, inverse is pulled low. I figured out a close source for 5v and everything already if that's ok with you.
