Old 03-26-2016, 05:29 PM   #2700 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by WindyDrew View Post
I was hoping to use an existing hook up like the led output.
OK - keep it simple - not a problem.
I think I would rather run it as forward is high, inverse is pulled low.
So there is a resistor already to tie the input high? That is convenient.
I figured out a close source for 5v and everything already if that's ok with you.
I'm OK with anything you want to do. I'm just paranoid and am mentioning things that I could see going wrong.
I'll sum up what I think you want in the next message. Do you have Paul's latest software? I want to make sure we are looking at the same thing!
