Old 03-28-2016, 08:36 AM   #8 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Sources for Vss ( vehicle speed sensor)
Originally Posted by johnbullas View Post
In the case of the tachometer (rpm) a 0/12v pulse exists for the Mega to monitor
In the case of the vacuum gauge a custom pressure/vacuum measurement device is required
In the case of speed the rotation of the speedometer cable needs to be monitored (and a turns per mile value used to convert to speed) else a hall effect transducer will need to be used !
The VSS senders I linked will provide this at a much higher resolution than 1pulse per tire revolutio. I used this one SPEED SENSOR, MECH TO ELEC, GM & CHRYSLER, 7/8"-18 THREAD, HALL EFFECT, 16 PULSE
On my 79 K-20(3/4ton 4X4 Chevy). When I custom built the dash all electronic. Something like 32000 pulses per mi on 33"s and 4.10's. Its been 9 years and no longer have the truck. As a bonus your stock mechanical speedo can be retained this just plugs inbetween your cable and Trans.
Gumby stay flexible
The Following User Says Thank You to gumby79 For This Useful Post:
Xist (03-28-2016)
