Old 03-31-2016, 05:48 PM   #431 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
The trick is to flash an empty sketch to the TinkerKit LCD. The timing is a bit tricky but it works well enough. When I have time I'll see if I can make cheap units using an ebay arduino nano, a cheap eBay LCD, and a postage stamp of PCB for the BJT, zeners, and resistors. It looks like the minimum BOM is $8 without case.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
The Following User Says Thank You to H-Man For This Useful Post:
t vago (04-18-2016)
