Old 03-31-2016, 07:40 PM   #17 (permalink)
freebeard
I'm not saying they don't have their problems. You picked two of the more common ones. The 56 sunroof had rusty rockers, the solution was to never run the heater. A cup of hot water in the winter to defrost the windshield, or a 6mil polyethylene 'cold cap' I stored on the porch. Others had a heater that was on in the winter and off in the summer.
Right now the Superbeetle is in the shop with the motor out, I'm making sure they replace the [torn] rubber grommet where the fuel line passes through the sheet metal. If it falls out the sheet metal turns into a saw that cuts through the fuel line.
I also once had a girl friend that was high maintenance.
