Originally Posted by Coyote X
do away with it all together if you think the carbon can is already dead.
Also when you set your timing did you ground that wire like it shows in the diagram under the hood.
I think I paid 30 bucks for all the rear bearings
Will it hurt anything to disconnect it?
Yeah I jumpered that connector.
Where did you get them for only $30? Autozone is a lot higher than that.
