Old 04-01-2016, 08:04 PM   #121 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by rmay635703 View Post
Actually the square block look is pretty popular, most Dodge cars look like that, so a little more height can add an opportunity for a certain unique flair.
(I love these type of projects)
That is very similar to what I plan to do. The lower side panels will be tilted outward from the mid-line ridge downward so that they cover the Prius V crash structure at the rocker panels. It will look somewhere between the original curve-under and the modern slab-side design made necessary by federal side crash regulations. Fortunately, the Firebird at its mid-line ridge is four inches (about 100mm) wider than the Prius V rocker panels below it.
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
mcrews (04-01-2016)
