Old 04-02-2016, 06:13 PM   #5 (permalink)
Paul9
Thanks people,
Thanks Ecky - I follow your logic as far as a belly pan is concerned. We put the car up on a hoist and attachment points were more rare than hen's teeth! As a result a belly pan dropped right down the "to do" list.
Thanks freebeard - I think I need more posts before I can post pics? In Australia, speed bumps, designed to slow cars down, can be anything from barely noticeable to almost requiring you hire a crane to get your car over them! I might stick with a 6" clearance.
Thanks aerohead - the repositioning you suggest was my first thought but I wondered if modifying the shape to a "U" shape might provide less resistance to air trying to get out the side of the car. Of course I forgot all about the "U" shape creating more front end lift which I don't need. I will look into the fascia designs you suggested.
Regards
Paul
