Old 04-02-2016, 09:15 PM   #1 (permalink)
tak209
92 civic vx sputtering/slight missfire at idle normal?
hello i recently rebuilt my 92 civic vx with the 5 wire o2 sensor. the car had a full rebuild with new valves and seals. new head gasket, piston rings bearings ect. only thing not new is the distributor. i replaced the cap and rotor and wires. and new plugs (ngk zfr5f-11) due to me being in central california a warmer climate and i will be commuting about 80miles for work a day. new cat, new ngk o2 sensor. timing is set to 16 degrees btdc. there is no check engine lights, and i have checked the egr system, which functions properly. fuel system and map sensor. all check out good. i have not checked the vtec solenoid. or the iacv but i dont think that would cause the issue. this is my first vx and i know they are temperamental. im wondering if this is just normal behavior like i have heard, or if i am missing something.
i also tried a spare 94 p07 ecu (4 wire) which threw the o2 sensor code. but it still ran the same.
im out of ideas. wondering if anyone has any ideas...
