Freebeard your citations contradict your statements .
From the 1st, "The electrically driven compressor shown below reaches its 70,000-rpm maximum operating speed in only a third of a second, according to its maker, U.K.-based Controlled Power Technologie"
From the 2nd one,"Mazda's efficiency-focused i-Eloop system feeds a supercapacitor and then uses the power to run the car's various electric components—but not an electric compressor."
"This is the technology that takes electric supercharging out of the realm of snake-oil fantasy and into legitimacy."
I stated:
As for heat and magnets agreed that js Why i stated ["The parts for 700°f do not exist yet most only have 200°c limmit".
/Resources/Temperature_Effects_On_DC_Motor_Performance.pdf
TABLE 3. Temperature Coefficients for Various
Permament Magnet Materials
Magnetic Material
Ceramic. -0.0020 / °C 300 °C
Samarium Cobalt (SmCo) -0.0004 / °C 300 ° C
Aluminum Nickel Cobalt (AlNiCo)-0.0002 / °C540 °C
Neodymium Iron Boron (NdFeB)-0.0012 / °C150 °C
αmagnet( / °C)
Tmax(°C)
All but NiFeB are above 432°f 200°C stated
"My thoughts 2nd turbocharger ,my rig already has1. Maby a vgt turbo link . Replace the impeller (as it is the thrust bearing pre load) with a spacer and direct cupple the BLDC400, 000 rpm motor/gen to the shaft." No heat on the inducer side with the inducer removed.
And PERMALINK 14
"This could could be mounted in the intake system after the Intercooler, " The IC (Intercooler )should be putting out air at below 160°f in 110°f ambient ,this is for a porely designed system . A premium system clocer to 140°f@110°f.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
