Old 04-04-2016, 01:01 AM   #10 (permalink)
tak209
Originally Posted by bryn View Post
my VX has the smoothest idle of any car i've ever owned. i see no change with e-10 or e-15 or whatever crap comes out of the boat and mower at the end of the summer,
my guess is timing, if the timing belt was off a tooth after that rebuild. that would certainly cause a bad idle. or a bad o2 sensor, find someone local and trade o2 sensors for a day or two,
well the o2 is the brand new ngk o2 that the car calls for. after tons of research i found that this one is the one to use. so i wouldnt think its that...
the timing is dead on 16 so if i was off a tooth my timing would be off significantly as when that has happened in the past with previous hondas, it was impossible for me to time it correctly...
