Originally Posted by MetroMPG
...it doesn't look like it, but there's 3.5" clearance (9 cm).
My guess is that this will reduce cd, but because you don't have full underbody panel and the Prius 2 is not very smooth under. The worse place is the rear axle beam assembly.
But with full underbody panels I don't think this is good for cd. I have measured 13 cm clearance under my Prius (with 80kg battery inside but only 5kg gasoline so may be 14cm for your's). 9 cm is less. With full underbody panels, why not just air dam before the 2 wheels ?
What is the following test after the police one ?
Could it be the AB test with/without the boat tail ?
![Big Grin](/forum/images/smilies/biggrin.gif)
Please keep the crash test at the end
Will your cd be always over 0.20 ?
Thank's for your sharing.
