Lupo 3l question
Hi guys. I am about to buy a Lupo 3l 2001. The car is in nice condition, and it is fitted with climatic, which is a big plus. It has 217000km on the odometer. I have never driven a car with automatic gearbox, so I need some advice regarding mileage and gearbox reliability. What should i look out for once i give it the test drive? I have already test driven an A2 3L, It wouldn't shift to the next gear when i gave it a full throttle and didn't let go. However, when i eased off of the gas paddle when it hit high revs, it did select the next gear. Is this normal? I suppose not... I know that the mileage is fine with the engine, but is the gearbox likely to start causing problems at the mileage in question? Thanks!
