Oil Pan
Good point.
I made a Hydrogen separator that used about 8 amps and inflated a mylar balloon in two hours. Thats probably 2.5 gallons an hour. The system only had one cell so it wasn't that efficient, i believe you can do up to 4 cells in series for almost quadruple the production off the same power. Plus with closer anodes and cathodes not needed for separation production goes up.
My car has 1.6 liter of displacement so thats about 750 gpm at 2500 rpm with an open throttle. A third of that is 250 gpm for normal operation. So 15000 gph.
Im at .15%
