Old 04-10-2016, 08:03 AM   #22 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by NoD~ View Post
Finally, confirmed the engine torque mount was done for. Figured, taking off in 1st feels pretty "long" compared to what it should and after shifting as well. Dealt with it in my Neon by filling mounts with urethane. I used the McMaster-Carr stuff before, but I'm going to try the 3M Window Weld this go-around. It's around $28 at the local auto parts store and should be a little easier to apply than the McMaster-Carr stuff.
That pretty much wraps up today. Oh, I also found the oil was about a quart too high (like 1/2" higher than the 2nd hole on the dipstick!) so I uncorked and let some drain out. Seems to be just below that hole now.
Important question!: I went to pull the plugs out because I bought some new ones. I went for the center plug first and it was really resistant the whole way out. Towards the end, though, it got REALLY hard to turn out. I got scared and put it back (I've stripped out a plug head on an old Neon and it was a nightmare to deal with). Anybody experience this before? My only guess is the threads stuck in the combustion chamber a bit and caught some carbon build up. Seafoam through the intake and let sit? Try it on a warm engine?! Just looking for some advice. Never had plugs turn ~10 times and only get harder to pull out before!
Two things. #1: DO NOT FILL THAT ENGINE MOUNT, OUCH, I HAVE DONE IT. Car vibrates worse than a million cats purring at once.
#2. You are pretty dedicated to that plug now, I recommend filling the spark plug hole with WD-40 and letting it sit overnight, but that many turns probably means the previous owner cross-threaded, and stripped the spark plug hole out. If it DOES break lose, and the cylinder does fill with WD-40, no biggie, just turn the engine over with no spark plug in it and blow all of it out. If you do snap the plug, or it rips all the threads out... Can't help you there. The car probably isn't going to run right now that the spark plug isn't clocked correctly anyway. But at least it runs.
If the spark plug does come out with no damage (let's hope!) then PLEASE use anti-sieze on the new spark plugs and torque to 17ft lbs!!! Do NOT 'guess' with tightness, and do NOT go in dry. The hole will not like getting penetrated dry.
The Following User Says Thank You to Baltothewolf For This Useful Post:
NoD~ (04-11-2016)
