Old 04-11-2016, 05:49 AM   #3 (permalink)
maczo
maczo's Avatar
scrapcento - '99 fiat seicento
90 day: 30.15 mpg (US)
fokus - '08 Ford Focus
90 day: 31.15 mpg (US)
tdm - '95 Yamaha TDM 850
90 day: 27.72 mpg (US)
vespa - '04 Piaggio Vespa ET4
90 day: 57.6 mpg (US)
PCX - '10 Honda PCX
90 day: 78.33 mpg (US)
avensis - '13 Toyota Avensis
90 day: 39.77 mpg (US)
Originally Posted by akeith8607 View Post
That is a neat idea for how to do those. How thick is that 3d carbon stuff? Do you think it could hold up without a backing or is it too fragile for that?
The one that I used would almost surely sag and get punctured easily, if not backed with a solid surface, it was pretty thin.
I am still using these BTW and there are no signs of wear. I also added lower grille blocks, but mounted them differently: each mounting point had 2 small holes for a zip-tie. Only after pushing the zip-ties through, I applied the 3d-carbon stuff. It doesn't look perfect, but is still quite discreet.
The Scrapcento thread
The Following User Says Thank You to maczo For This Useful Post:
akeith8607 (04-11-2016)
