Old 04-11-2016, 08:37 AM   #5 (permalink)
kach22i
Originally Posted by ByDesign View Post
Finally, beware of the 2d limitations in thinking when viewing shapes like these. Sides of the vehicle are just as important -and ground effect too.
Yes, true - true - true.
One thing I've noticed in many of the wind-tunnel videos I've watched is that the stream of smoke which actually manages to go over the roof seems limited to one 4-inch wide spot dead center on the upper lip of the front grille.
A notable amount of the smoke coming out of the wand/probe goes off the top of the side windows and an alarming amount get blasted at the side view mirror area with just slight off-center locations.
Going back to the plan view importance; based on the smoke tunnel videos it appears that just about 1/4 the air mass, 1/8th each front corner runs along the lower sides of the vehicle.
Makes sense if we allocate the air pattern as seen in the attached marked-up (by me) photo.
MORE random pics...... - Page 3858 - Pelican Parts Technical BBS
