Old 04-16-2016, 01:44 AM   #2 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
I have the latest DC controller running, codenamed Stinky diaper
Laptop is running windows 7
RTD_EXPLORER installs on windows 7 and runs.
The rtd-period is set to 100 ms and between 1 and 30 updates are logged before the terminal on the right freezes.
It starts again when you disconnect/connect.
Debug mode does not appear to do anything different. But it stops just as quickly.
There seems to be issues communicating when the controller is running. I have it logging in Hyperterminal on an older XP SP2 machine - the issue may be noise, but I don't see the noise changing between logging on different laptops?
I'm using a crappy USB to serial adapter ... is there a brand or a chipset that works well that I can use?
