Thanks for the quick response Adam.
RTD Explorer is expecting exactly this format ... can I put other information on a second line?
ie
Code:
first set of data
TR=000 CR=000 CF=012 PW=000 HS=0261 RT=0716 FB=00 BA=000 AH=42.0
003, 14, 3.33, ... 23,
second set of data
There is more data to log, and if I can send it all on interleaved lines then it saves adding another command, adding another variable to keep track of the state, adding that variable to the config screen, etc
