Old 04-18-2016, 08:31 PM   #25 (permalink)
cRiPpLe_rOoStEr
It's all because EPA test procedures are more favorable to close-ratio transmissions instead of wide-ratio ones, so in order to keep a high gear spread to retain a decent performance with fewer compromises more gears are added. In regard to SUVs, adding just a crawler gear is perceived as less weight-intensive than resorting to a 2-speed transfer case.
