Old 04-19-2016, 01:26 PM   #14 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Pre heat control
How about running a 150° -15f. fan control switch NC (normally closed) just above the heating element~ 1" (get it as close as the threads will alow). Like this (°.) one above the other . This would cycle As the viscosity is very high when cold. Heated fluid would trip the switch alowing the elements to cool .I'm guessing that in a thick fluid ~1"above the element @150would be @180+- down at element surface, experiments are needed to un gess this part.The residual heat would convect cooling itself and controlling sender turning the power back on. For higher viscosity diff fluid a lower temp. setting may be needed to keep from burning the fluid.
adjustable 160°-240°f -15° normally closed switch
This switch is active(closed) up to the set point then opens the circuit cooling 15°f reestablishing connection, and backand forth.
-----220°f sounds kinda hot
I used a similar chart to explain why a Trans. Cooler was "nesasary " when adding a hitch to a car ,van,or non-towing package vehicle back when I worked @U-haul as a Hitch Pro.
Sold 1 cooler out of 60 hitches ~250 hitches a year.
GM was having a lot of auto trans. Over heat failure problems when they bumped the Corvette up to a 210°f thermostat. Back in the early 2000s
Would running 2 heaters in series cut the heat output in hafe?
If so ,then 2 600w heaters with more surface aera would put out 300w ea. Reducing the chances of burning the atf resulting needing a transmission service @$$$ or failure @$$$$ synthetic atf is spendy. Rebuilding is more than any possible FE savings.
Gumby stay flexible.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
