Old 04-20-2016, 11:11 AM   #30 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Well, I Got me an Insight... so that means I could FINALLY put some dedicated time into the red Neon!
We are going on a road trip shortly, so right after getting the Insight, I was able to get this done...
It didn't turn out perfect, but it should work for now. Here's the steps...
I Put on a cargo carrier on the back. Had a friend weld a bit of angle on it, as it seems to sag down a degree or two. Should keep from scraping (and hasn't yet!)
Coroplast from bumper to all under the carrier. Made a new rear end with all LED lighting.
Made some framwork from 3/4" plywood.
Last time I took this same trip about this same time of year, I pulled in 57-59 MPG. I'm hoping to see 60 this go.
2 big mistakes I made (and I blame time frame... mostly):
-The shape at the top of the removable back window is too side. Looking down the side of the car, I can clearly see it sticking out a bit. Should have cut that a little more.
-The window I used was some clear vinyl table cloth from Jo Anns. It is blurry and not stetched well. May try to get it fixed before we go.
Wish me luck! 1000 miles about to go down...
The Following 2 Users Say Thank You to NoD~ For This Useful Post:
aerohead (04-21-2016), Ecky (04-20-2016)
