I finally came up with the perfect idea for the grill block. Use drywall toggles and have it hook inside the front grill. Make it in 3 pieces so they can be removed to allow cooling in the 115+ AZ heat during the summer. I was also thinking of smoothing where the fog lights are by covering them in some sort of abs plastic or such with double sided tape. Would that help enough to be worth doing? I just thought that they grab enough air and since I don't have fog lights to just smooth them out. Now how would I slow down the power steering or the water pump? The belts are all on the side of the engine like no neighing I've seen before. So I just am clueless.
