Old 04-25-2016, 05:47 PM   #98 (permalink)
freebeard
teknomage2012 -- OEM FTW
Can you post a picture for size comparison? The Toyota/Lexus MGR is 50kW/68hp and 98lb.
What chassis? Suzuki Samurai? What might be interesting would be a VW sand rail converted to 4WD.
Isaac Zackary -- Built to John Karcey's original spec (less the 50lb pulley) before the HVW series. They went with fuel injection heads for the smaller exhaust valves, but I used CB Performance big valve heads because I thought I might run CNG.
I did the Type IV cooler with Gene Berg parts.
Isaac Zackary (04-25-2016)
