Old 04-29-2016, 01:02 PM   #51 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
I'm trying to knock down as much as I can while I'm motivated! lol
I checked the rear brakes, the pads looked good enough. Bled those out while I was at it.
Got new brake pads for the front coming. New idler on the way as well (already got the belt). Might not need replaced, but it's $15 to just get it over with, so figured it was worth doing.
Grid charger his about 172v and has been hovering around there for a while now, so I'm guessing that's where it's hitting the ceiling. Still need to figure out the discharge system.
I also found an easy fix to the trunk lock actuator. I took apart my driver's door one that I pulled out (that still worked) and, whatya know, same motor! So, swapped them and now it locks and unlocks just fine.
The Following 3 Users Say Thank You to NoD~ For This Useful Post:
Ecky (04-29-2016), fusion210 (04-30-2016), Joggernot (04-30-2016)
