Old 04-30-2016, 04:56 PM   #2 (permalink)
Xist
Do I understand you correctly?
I italicized the words that confused me. I am honestly just trying to make sure I understand.
Warm air intake (wai) with controller all mechanical
There is much talk of a WAI (warm air intake) and how it could be done , but alas the idea seems to get stalled when the power loss/loss of FE (Fuel Economy) from uncontrolled IAT. Too cold / hot is bad for economy. Cummins states 1%power loss per 10°f above 60°f. EG. A 250HP diesel will produce 240HP with the same fuel demand as 250HP at 90°f IAT (Intake Air Temperature) this is measured at the intake manifold. So here's my Idea for controlling the IAT with a WAI
The old low tech.answer is found in the carburetor /TBI (Throttle Body Injection) air cleaner.
A bi metal adjustable thermostatic Vac.(vacuum) Switch
Sounds good to me! In theory, couldn't you use this technique to open vents on smooth wheel covers if you need to brake hard?
gumby79 (05-01-2016)
