reply
Don't you need high AOA for heavier aircraft, not for lighter aircraft since high AOA at same speed will allow for more lift to be generated.
What I was curious about is whether or not you can increase the speed while reducing or keeping the same AOA, and by doing so you would get to the destination faster. Is this simply impossible to achieve due to limitations on the engine or..?
