Old 05-01-2016, 02:45 AM   #8 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Ok, look at it this way.
two planes, A and B
Each plane is the same but plane A weighs more.
At any given speed and altitude, in unaccelerated level flight, plane A must have a higher angle of attack.
Going faster makes no difference. Plane A must have a higher angle of attack to produce the needed lift, to overcome that added weight.
Speed up both planes and look again. Plane A still has the same problem, still has to fly at a higher angle of attack than plane B does.
Unfortunately speeding up has a big fuel penalty. Drag increases as approximately the square of speed.
Thrust increases as approximately the cube of speed.
To go 10% faster could require as much as 33% more thrust. Not a good tradeoff.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
maxkang (05-01-2016), MkVer (05-08-2016)
