Been brainstorming some bracing arms fer the hitch to better stabilize Dark Aero from yaw forces. I should be able to drill and tap a bolt into each side of the main cross beam without weakening the cross beam and bolt in ears fer easy attachment points. A clevis pin should keep the bracing arm in place and it will attach to ears bolted to each side on the bottom of the bumper via another set of clevis pins. This should enable me to remove the Hitch Vise that I have been trying use to stabilize Dark Aero from pivoting in the hitch receiver.
