Old 05-01-2016, 11:50 AM   #4 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Here is the short answer.
During the ground roll, Tire friction is a significant portion of the total force to overcome in the first portion. Then as speed increases parasite drag, and parasite drag only that is added.
There is no induced drag until the aircraft has an angle of attack. It all comes back to that.
On the ground most planes have a negative angle of attack until it is pitched up and nosewheel lifted. This is called rotation.
At that moment you start to generate lift. The wings bend as they are loaded.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
ChazInMT (05-01-2016), freebeard (05-02-2016)
