Busy car weekend!
Got the low beams working again, I'm pretty pumped about that! It turned out that the snap plug was too bad to be fixed, so I bought the plug with wires and a lower column housing from a guy on IC, and installed it this weekend. So far so good, but I'll need to re-aim the head lights when I'm sure they'll continue to work.
I also re-installed the OEM side view mirrors. I'm going to send my custom tiny ones to Daox so he can re-fab something even cooler off his 3D printer. While I had the door skins off I re-adjusted the door poppers, both are working perfectly now.
I also discharged the IMA (down to 40V) and grid charged it. It lasted about 4 months last time before I had the first force-charge, not bad!
