Old 05-03-2016, 10:54 PM   #394 (permalink)
freebeard
Pulling some pictures forward as a point for discussion.
http://ecomodder.com/forum/showthread.php/hot-rodding-toyota-mgr-29878-12.html#post451148
http://ecomodder.com/forum/showthrea...tml#post451798
Currently in hand:
  • Lexus MGR
  • rear mount - 81651G
  • front bolts - 90109 12082
needed
  • crossbar - 52380F
  • washer/spacer - 41653D
Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - freebeard's Album: aero technical - Picture
The rear mount (81651G) appears to float in a round cutout in the subframe with little constraint fore-and-aft. The front mounts are on about a 4" lever arm. The connection is about 6" directly above the VW transmission mount. The rear mount face is in plane with the VW engine/transmission mount.
Replace crossbar - plate box or U-shaped tube?
Toyota or VW rubber mounts or both?
