OK, so I've been trying to get some stuff done on this guy...
-Pulled the rear wiper (not the motor, yet)
-Removed the EPS controller (now no notification lights on the dash! woot!)
-Removed intake resonator box
-Changed belt + pulley on engine AC/Water pump system
-Changed transmission fluid to BG SyncroShift II (old fluid unknown, but looked decent still)
Upcoming shortly...
-Brake pad change out
-Fix rear bumper bottom (no buttons, hangs down like a parachute!)
-Rear MM swap
-Upper & Lower Grill Blocks
-Passenger mirror delete & interior mirror install
-Discharger setup, do some deep cycling
-Block heater & Trans fluid swapout
-Clutch fluid bleed
I have a lot more planning in the pipe, but lower priority stuff.
Question: Is this belly panel on the passenger side supposed to resemble a ruffled potato chip?
