On bitog forum vehicles with K&N type filters tend to have 3 to 5 times the Si content in the oil as compared to paper filter vehicles. Used oil analysis tests after using paper then K&N and back to paper air filter tests have been done.
If you are a stupid redneck or ricer kid that blows up their vehicles engine every 20,000m or less then K&N is perfect for you.
If you want to keep your engine going past 100,000 miles or have a turbocharger then use paper.
If you drive in a dusty environment use paper.
