What's my '94 VX swap worth?
I hope this is allowed.
Recently pulled almost everything off of my '94 Civic VX that made it a VX.
I have a guy that's interested, but I'm not sure what it's all worth.
177,XXX original miles
Entire engine, trans, harness, ECU, mounts, axles, shift linkage, EGR components, exhaust from manifold to muffler, radiator/fan/hoses/overflow tank, gauge cluster, front lip, wheels with almost new Michelin tires, airbox/hose, throttle cable, fuel filter, and factory alarm box.
NEW...timing belt, OEM water pump, OEM head gasket, valve cover gasket, intake/exhaust manifold gaskets, OEM alternator, OEM O2 sensor, plugs/wires/distributor, belts.
*Recently passed Georgia emissions!
Only problem.....VTEC pressure sensor is broken.
I'd really appreciate any useful input. Thanks, in advance!
