Old 05-09-2016, 04:07 AM   #11 (permalink)
freebeard
I'm thinking that sure, it'd increase back pressure and actually hurt performance during use, but not enough to damage anything...
vs
I've read in other gas engines where exhaust water injection is used to create a reflective wave which dynamically "tunes" the exhaust system (via exhaust gas scavenging) to improve torque and horsepower at rpm bands other than what the original system was designed for.
Did anyone bring popcorn?
Steam for lift
Hydrogen gas has a standardized lift of 11.19 N/m3. Helium has 10.36 N/m3 lift, while hot air varies from 2.7 to 3.2N/m3. Pure steam has 6.26 N/m3
Find an article on the relative merits of the various lifting gases, including losers like methane and ammonia at Steam Balloon JBFA Article
'Steam' power
The world's tiniest [theoretical] engine uses water as a working fluid, but without the phase change:
https://www.washingtonpost.com/news/...allest-engine/
The University of Cambridge engine needs a bit of refining before it can be hitched to a nanoscale object. “Our main challenge is how to build a device that harnesses the forces for motion in one direction – a bit like a piston on a steam engine,” Baumberg wrote. “Currently the force just expands and contracts in all directions.” But a few steps down the line — once the directional problem is solved — he envisions “tiny nanomachines that can walk around, controlled by beams of light.”
