Old 05-10-2016, 11:30 AM   #49 (permalink)
roosterk0031
Never tried antifreeze, but have seen the Ride on motorcycle tire sealer balancer so tried using regular Slime in a couple car tires, didn't notice out of balance for a while but they didn't wear very well and had to replace while they still had quite a bit of rubber left.
I get an out of balance situation about once every 2 weeks with my cobalt using counteract beads. Sometimes it will go away at speed other times it persist until the next stop. Happens occasionally with the Impala as well. I wonder if happens more often now than in the past is the contamination of the beads as I've used them in multiple tires.
I've never experience a shake with KT's cobalt or the Altima but don't drive them that often, both are on the first tire change and new beads. I might have to give up and buy new beads next change or come up with a way to clean them.
