Try the antifreeze and report back here!
I'm pretty sure that's what I'm going to try since I have some laying around that will probably never get used. It should be easy to remove the tire cores and syphon fluid in with some clear tubing.
How much fluid should I use in a wheel that already has balance weights on it?
