Old 05-10-2016, 02:05 PM   #1 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Re-visiting a clutched power steering pump
Based on both oil pan 4's excellent work on figuring out how much power a power steering pump draws, this Hot Rod article I found that gives a bit more power loss detail for Mopar engines, and the original inspiration for this idea, I've decided to go ahead and try to attach an A/C compressor electric clutch pulley to my power steering pump.
Ecomodder: How much energy does it take to turn a power steering pump
Hot Rod: Mopar Engines - Power Vs. Luxury
Ecomodder: Electric Clutch Power Steering
Basically, I want the power steering to be power-assisted at speeds only below 20 MPH, and to disengage while the vehicle is stopped and the engine speed is below 900 RPM and the brake pedal is pressed (with an override, of course)
