Old 05-11-2016, 08:16 AM   #4 (permalink)
oil pan 4
The problem is the power steering hydraulic pump requires quite a bit of power just to circulate fluid around the system when you are not needing any power assist. It actually takes very little hydraulic power to use "power steering" to move the wheels to the left or right when sitting still.
When driving along down the road the power steering takes up to 1 horsepower just to circulate the fluid, when its not even doing anything as far as you are concerned. Then when you need it the power steering only takes around 2 horse power to run the pump its self to push the rack or steering arm one way or the other.
Xist (05-11-2016)
